Lower or Upper ball joints?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
yuppers find out frist if there craped out any way and don't buy the cheep ones or they will just pop over short period of time
jdub
Feb 10, 2006
10,730
Valley of the Sun
The upper ball joint is part of the upper suspension arm. The lower ball joints are usually the ones that wear out...they carry much more stress from the suspension.
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
Guys my headlight went out and im replacing it soon, is it the left or right that needs replacing?
haha just kidding matt! ;)
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Are the ball joints sealed, or can they be re-greased? Bi-Tron just came out with a new grease.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Keep your fingers crossed that it's the lower, the upper cost 6x as much. Yes, the lower are more common.... figures it's one of my uppers that died. Definitely check them before you just start ordering parts.
On the topic of the upper ball joints, does anyone know if it's either possible to or if anyone has had a set of control arms machined to accept a replacable ball joint? I'm looking for a used control arm with a good ball joint and figured that if it 1) could be done safely and 2 could be done for the cost of or cheaper than a regular replacement, it'd be more than worth it. Finding a good joint to use and ensuring structural integrity are the issues.
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
As long as your there do both!!! And Nashman is so right cheap ball joints= trouble. Its $25-30 for cheep joints or $50-60 for good ones!!!! Buy the good ones.........................................
supra90turbo
shaeff is FTMFW!
MA, 01440
soup: Do both? By both do you mean uppers and lowers?
The lowers are around $60/ea for good ones, but the uppers are a part of the control arm, and cost $400/ea
Matt: You're the only one who knows whether you need lower or upper ball joints. Get the front of the car in the air and put your hands at 12 o'clock and 6 o'clock on the wheel and wiggle it while someone looks at the ball joints to see which are moving.
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
I'd say 95% of the time it is going to be the lower that is worn out, and it's cheap enough that even if they're not, you might as well replace them anyways. The uppers are going to be expensive, at least $600 to do both sides for the control arms.
da89soup
Dec 2, 2005
1,978
Fargo ND
^^^^ I did mean uppers and lowers!!! I wasn't aware of the uppers being part of the control arm. Looks like next time Soup will look at his tsrm before he answers any more questions and looks like a dumb ass!!!! :icon_bigg
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
DAMN you and your Bi-tron stuff LOL j/k but that looks interesteing as well I like there Oil aditive.
Back on topic
If you have the time change both.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
if my upper ball joint goe si just going to make custom upper a arm so i can add negtive caber kidna liek the jic's but wiht out the price
