low rpm knock advice
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
ok the facts, 1988 supra 7mgte, rebuilt by me, 20k miles so far, automatic
aftermarket blow off dont know the name of it. was on the car when i got it
new plugs coper gaped to spec.
fresh oil changed last night 15 w 40
sounds like rod or spark knock
when i go above 900 rpms sounds is gone
please advise
-David
ATL88Supra
The Asshole
Jun 22, 2007
497
IJ. said:
Dave: What's the static timing set at?
Is this under load or free revving?
free revving, note if i turn on the AC the noise will increse untill 1000 rpm is reched then it go's away or if i put the car in gear, mostly it happends when ever the rpms dropto 900 or below
ie, the car is sitting idling i turn the wheels some and the knock gets loud cause of the load of the power steering
also note there is no knock when the car is cold.time
edit: timing is set correctly per tsrm checked it 10 mins ago
Edit edit: when i put the car in gear and drive the sounds dissapears
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
hook up an oil pressure gauge, you might have low pressure at idle. Mine has really low pressure at idle but normal at all other rpms. If i blip the throttle to the floor when its idleing at around 750 rpms i hear a light knock, not sure if thats cause of my oil pressure or what, but ya, put a pressure gauge on it and check the pressure at warm idle
ATL88Supra
The Asshole
Jun 22, 2007
497
i am sure its not oil pressure, as i have a new oil pump that is shimed
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
its not the pump itself that would result in low pressure in most cases, when clearances are made larger (wear) oil pressure (resistance to flow) goes down
