I got my car running yesterday and have a few issues. My dash is out so I dont have my MIL code light right now. I have the necessary gauges hooked up for engine health. Once the car gets past 1500 rpm it cleans up and runs good but stumbles as the idle falls then tries to die and idle rough. The car is pretty stock with bigger IC, 3" down pipe and open 3" exhaust, K&N airfilter, recirculating BOV, still has EGR, fuel system upgrade, stock electronics.
Idles at 500 rpm (low)
AFR is 10.0 at idle
AFR jumps around lean rich as I accelerate
This is what I did:
Set fuel pressure per TSRM, Aeromotive fPR walbro pump all DM lines.
tested and set TPS, Idle air control per TSRM
tested and set dashpot
tested water temp sender, good
tested cold start injector, good
tried testing MAF but not really sure if Im doing it right, TSRM says to check ohms across two terminals then gives a number of specs for different temps, but thats it??
What else would cause these symptoms??
It was all fine when I took it apart and I didnt modify any of the elecronics, all stock, I did clean it all real good before tear down so I think water may have damaged something?? Or something is stuck from sitting??
AFR is 10.0 at idle
This is what I did:
