Ive got a 7mge with 80k miles on it, and when its idleing at around 700 rpm the oil pressure can get to as low as 2-3psi sometimes, but as soon as i start moving the pressure seems pretty normal. At 3k rpm it usually wont go any lower that 50psi when fully warm. Is this caused by a pressure relief spring or is it an engine bearing problem most likely? THanks.
By the way, i am running a napa gold filter with 10w-40 castrol oil right now. I am using a prosport oil pressure gauge. I have had a problem with this gauge previously where it actually read 0 psi, and i had the sender warrentied, not sure if this one is also acting up or what, the problem is if i just let the car idle to warm up the oil pressure never gets to full temperature, so i cant use a mechanical gauge to figure out my lowest pressure, its after ive been driving around town or on the highway that my pressure gets its lowest and i cant have the mechanical gauge hooked up while i go cruising around.
