Clip;1141707 said:
i just got done with a ge rebuild, ran me about $4000
rebuilt head, new pistons, ground crank, decked block, all gaskets. also had arp rod bolts and head studs, and new clutch/pp
O_O
:aigo:
Dude..... full, freshly rebuilt GTE would have been about that much if you did some of the work. i hope that price includes a lot of labor. That crazy for a GE...
626na;1141728 said:
That too.
Phantom: My bhg fix cost me ~$500 after all was said and done. That included new coolant hoses (3-5 of them), ARP studs, Toyota HG, Used head w/ new valve seals and machined flat, helicoil kit and some other small pieces.
If you pay a shop to do it, it will likely cost 1500-2000.
To check for oil in water, look under oil cap: If you see a milky, light brown color, milkshake-like substance you have a bhg.
To check your coolant for oil, see if it's brown? :dunno:
To check for exhaust gases in coolant: Get a block test kit; sometimes called combustion gas test kit.
If you keep losing coolant look on the exhaust side of the block and search for dribbles of coolant. Many hoses on that side can develop small leaks that may only leak when hot and be evaporated from you exhaust heat. I was losing coolant for some time after my bhg fix with no leaks on the ground.
See my sig link for more bhg info.
