I've had a low and bouncy idle for awhile now, I would usually have to rev it up to keep the rpms at around 700-800 only when the engine got warm.  Now it has gotten worse, after a cold start it takes about 30 seconds for it to have a low and bouncy idle (dances around 400-500) almost to the point where it stalls, but it doesn't.  Things that I tried doing so far:
Check Codes - None
Clean Idle Speed Control Valve
Check for Vacuum Leaks - (It Idles at vacuum inbetween 16-18 when its at 400rpm)
Any ideas? Here's a video to better understand...
http://www.youtube.com/watch?v=lDFOsMTqiXk
			Check Codes - None
