low boost
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
ok i have 2.5in exaust and intake. i cant seem to get my car to boost over 5psi in 2 gear . so i shimmed the wastegate with 4mm i think. i thought maybe the spring was weak. i didnt really do anything, until i got into third then it went to 8 psi. i read that you dont always build full boost till second gear but i cant get it too. ?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I've got a 3" exhast (well half one, stops at the test pipe) and i boost really fast and hard (stock psi for now). My car came with the pacesetter catback (2.5") and I couldn't spool for shit when I put it on (that's why I've just got half of one right now.
I'd say your problem is in the piping size itself. GET RID OF THE STOCK TURBO ELBOW. Once that's done, BAM! big power difference. On turbo cars, the bigger the exhaust the better.
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
i had it rebuilt by a certain person and when i put in on after about a day or two in started whining and the bearings were shot. so i bought a used turbo to put on because i wasted so much money on the rebuild.
xXxICExXx
366
Abbotsford, BC, Canada
hmmmmmmm.....can you take a picture of your engine bay? My car used to do that and its because the guy that rebuilt my car last year connected two vacuum lines in the wrong place.:nono:
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
thank you i geuss. i have a wife and a kid so i am broke. i just done it to see if it was the wg. i do anything i can to fix and keep my car. i just knew 7 was lower than what i was running without the shims. i guess i will swith back to my other wg.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Even better reason not to increase the boost, just keep it where it is and drive it. When you start increasing the boost is when bad things happen. 7 psi is totally normal. If you are reading the stock boost gauge then that could be the problem, the stock one is sooooo slow.
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
like i said i wasnt doing it to increase the boost higher than stock i just couldnt get it to read the stock psi without shimming it. i dont even have the shims in there anymore. i just want to know what is causing me not to have normal boost.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Possibilities:
Boost leak
Turbo on the way out
Clogged cat
Gauge wrong
Wastegate spring weak
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
Wastegate spring weak- thats what i was trying to eliminate with the shims.
Clogged cat-new cat
Turbo on the way out-used turbo possibility
Boost leak- good chance
thanks man
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I believe your car should fall off on power in the upper rpms due to the restrictive stock ic piping and intercooler. Get those bottlenecks out and that should clear up the loss of power up top.
