Ok so they were on the other day then suddenly stopped. The fogs will still come on and the high beams work but no low beam. Checked for voltage and theres none. Ideas? My first thought was the relay. Though I do not know where its located.
RiyadYar;1270110 said:on both sides ?
Poodles;1270287 said:JJ: I had just the low beams fail and it was the Integration Relay #2, didn't make sense from the wiring diagrams, but changing it fixed the issue.
Almost sounds like you popped the headlight fuses in the underhood fuse box, I blew one (messing with wiring and accidently shorted) and the light was super dim but on...
CordiaDOHC;1280604 said:... replaced the retractor relay. Still no go...
