I know I was being stupid, and I know I should recognize this noise, but I cannot undo the past, and I would like to learn.
I went 120mph on the highway, and put the car into neutral to slow down. My Mass airflow sensor is bad so the car cannot idle correctly and it shut off at 120mph. I pulled to the side of the highway and started it up. After accelerating to about 40 I heard the noise in the video, I immediately took the next exit and drove to a side road and parked. I got my laptop out and took the video. http://www.youtube.com/watch?v=NMk6hNeooxs
When checking the oil I saw that it was pretty much gone. I had checked it 2 days ago and it was 100 percent fine.
I also checked for exhaust leaks and the exhaust burned me, pretty bad (have burns on skin) but the stock temp gauge is only about half way up.
The engine runs low on coolant (there is a leak somewhere) so I put water in and that may have helped cause this problem. I also noticed my overflow tank had overflowed and squirted all around the front of the car.
Please help, and post ANY opinions. I know that a few things I did were stupid, and I am not that great with cars, (hope to be someday) so I don't know what the noise is.
Thanks for any help.
EDIT: I should add that I never went above 6k RPMs EVER, probably about 5500 max
