I recently rebuilt my 7mgte, but have been plagued with losing coolant from the overflow tank since day one. Runs fine until I really get on it. The car makes 402 whp, and compressioned tested at 180 multiple times.
Using arp bolts and a mhg torqued to 95 foot-pounds, and it has been retorque since break in.
It has always over pressurized the coolant system since day one.
Block was magnafluxed when built, the head was not tested just shaved and made smooth. Was recently rebuilt and gotten grind jobs, so I assumed it was ok.
I have changed the radiator caps a few times.
Car doesn't smoke white or at all for that matter, oil is clean, and radiator fluid is clean
I suspect I have a cracked head that only shows itself at high boost.
Is there any other possibilities or suggestions before I rebuild a new head?
Thanks for the help.
