loosing coolant
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
Hey guys, I just got done with a mild rebuild (catch can, new IC pipes, relocate the power steering, etc) It started right up....and it seemed like it was running fine. Then I drove it for a while and the bird cage (BHG) light comes on. I pulled over and looked in the overflow reservoir, and it was almost empty. There was coolant all over the intercoler and the reservoir. So i pulled over and added coolant to the reservoir and to the radiator, it went away instantaneously. So I kept driving for about 10 minutes and then lit up again. Again I pull over and the same thing happens.... I never had this problem before..... I noticed that even at idle the coolant is dripping through that little hose from the reservoir tank. Any ideas ???? help or suggestions are always appreciated!!! Thanks
ma71supraturbo
Redding, CA
www.geocities.com
your coolant is getting pressurized and is being forced out... Possible causes (in order of cost to fix):
Debris stuck in front of radiator
Bad radiator cap
Thermostat stuck shut
malfunctioning fan clutch
BHG
ma71supraturbo
Redding, CA
www.geocities.com
If you did have a leak and happened to have a low level of coolant -- it could also explain it. But you described it emptying the system so rapidly that if there were a leak you'd know what general area it is in (and the only hose over the IC is from the overflow).
The only other possibility is a bad waterpump, but it's fairly rare. Try running with the heater on full blast... If the air coming out of the vents alternates from cold to hot and back -- you've got air in the system (either from leak or BHG)
xXxICExXx
366
Abbotsford, BC, Canada
black87turbo said:
I just got a new radiator cap, new thermostat, and a new fan clutch........ that leaves me with only one ther choice :cry:
Not neccessarily. My first thoughts when reading what you posted was thermostat. Its new, but is it installed correctly? :icon_razz Just because something screws up with the rad doesnt mean its a BHG lol. If you JUST got a new cap, thermo and fan clutch, what do you think the chances are that something wasnt installed correctly? I think those chances are prettty good. Check over everything thats been recently done involving the coolant system.
johnathan1
Supra =
Aug 19, 2005
5,056
Pressure test the rad cap...I bought one new from Toyota, and it turned out to be defective, and wouldn't hold as much pressure as it should have, I think it was like 9-10psi when I tested it, and it should have been 13...:nono: It exhibited the same symptoms you are describing.
I bought ANOTHER from Toyota, and it has been fine ever since.
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
Well i actually swapped out a few turbo coolant line aside from doing the thermostat, so I wasn't exactly sure how much fluid was there to begin with. I just filled up the radiator after I started the car and I figured it should have cycled itself right?? I think I will try a flush and test the radiator cap as well as the thermostat first. Thanks for all of your replies...
