Looking to remove ABS
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
Well just bought it and set me back 436.40. Good thing the proportioning valve was the same. Other than that engine compartment lines and new master assembly. Not bad and I don't have to worry about sourcing parts from a yard. Looks like I have somemore stuff to take out before the turbo arrives. Thanks for the help guys.
VooDoo
Mar 20, 2008
342
Valdosta ,Ga
Well the mastercylinder was 300. I don't mind spending the money. I haven't had to get anything from the yard yet. But I would if a good quality part was there. We just don't have any cars local. And I'm not takin my chances on there shipping. Nice find if you got the complete system for that price.
dbsupra90
toonar
indiucky
if you decide to go with a line lock, i like the biondo. it is cheap and works well.
http://www.summitracing.com/parts/SBR-LL/
installed:
johnd
278
Ont. CA.
I just ordered the master and four of the lines from champion, they said the two from the master to pro valve were discontinued.
Suprised how cheap the lines are, i don't think i can get the fittings localy for that price.
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
there was no need to switch the master cylinder. the only difference is where a line outlets from the cylinder. the bore sizes are the same. also you should have gotten a 50 dollar master cylinder from napa anyway
Internals are different. Not sure on their exact effect though.
supraguru05
Dec 16, 2005
737
louisville ky
hmm interesting. my guess would be the internal differences are just for the different port locations, however i dont have a NA master cylinder laying around. I am using the original ABS cylinder on my car without abs and have noticed no ill effects.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
With-ABS and Non-ABS have different Master Cylinders. 1986-1990 and 1991-1992 with-ABS are also different.
That means there are 3 types of master cylinder: 86-92 non-ABS, 87-90 with-ABS and 91-92 with-ABS.
On 86-92 non-ABS and 87-90 with-ABS master cylinders, the front port is for the front brakes and the rear port is for the rear brakes.
On 91-92 with-ABS master cylinders, the front port is for the rear brakes and the rear port is for the front brakes. The front port (rear brakes) is also an "orifice-type" which "reduces idle stroke and improves brake pedal feel."
I know the clutch master changed from cast iron to aluminum for 1991, this may also have been the case for the brake master as well... can't remember anymore.
Jeff
supraguru05
Dec 16, 2005
737
louisville ky
Jeff
thanks jeff thats the information that everyone needed.
