Looking for tsm on 2jz timing belt
tsuper92
supra addict
Apr 7, 2005
1,376
mass
2j is not the same.you need to get a timing belt for a isuzu pick up with 2.6L 4cyl .its like 137 teeth
tsuper92
supra addict
Apr 7, 2005
1,376
mass
sorry.i misread the thread.cam markings need to face straight up (there is markings on the metal cam gear cover)and the crank marking to the 0 tdc.unbolt the self adjuster.keep all your slack on the adjuster side.once you got the belt on just roll the motor over a few times and make sure they keep in-line
Ken
350
Houston, TX
don't forget about the tensioner. if you have never changed a timing belt on a JZ engine, you will need a bench vise or a hydraulic press to push in the pin. once it's pushed in, use a small hex key to retain it.
also make sure to not push the hex key too far out; it will get in the way when you are reinstalling the tensioner.
