Location of anti theft deterrent
SupraDupra907
AK-907
Jan 28, 2008
51
North Pole
Zumtizzle;1326375 said:
Brake Pedal.
If you're stealing a MK3 supra good luck.
The speed control is by the brake pedal...
It's my car, it just does not want to start. Bypassed the starter relay and it started up. Checked to see if the starter relay was good, and it was working fine. Wire diagram leads to the anti theft deterrent. Can I rip this out?
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
It's there and a Green or Black Box.
It's attached to the brake pedal except very high up there if i remember right.....
SupraDupra907
AK-907
Jan 28, 2008
51
North Pole
Okay cross all of that, I guess the anti theft locked the car from starting. I google'd, and found a guy who said locking, then unlocking the passenger side door with the key resets the theft. Well, it sure did work. Car starts right up now!
shaeff
Kurt is FTMFW x2!!!!
11
Around
Zum- it's located on the steering column next to the firewall. ;)
SupraDupra- Replace the switch in your driver's side door, and that should fix your problem for another 20+ years.
