little problems
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
This might sound a little weird but my passenger window only goes up with the passenger switch and only goes down with the drivers switch....does anyone know why? And yesterday I realized my left turn signal on the dash stopped working after installing my speedometer cable....could i have messed something up?:1zhelp:
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
the window switch thing is VERY common. Typically its because of dirty contacts or a faulty master switch. Try disassemblind the master switch and blowing some compressed air at it a bit and see what happens.
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
thanks for the advice
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
yes the switches arent that hard to take apart, but I suggest in addition to some air that you use some contact cleaner and follow that up with dielectric grease just before re-assembly.
Sep 10, 2007
482
Virginia
thats a weird window switch problem, i've only seen one side working and then not the other. like theWeezL said, don't forget the dielectric grease when you put it back together.
as far as the turn signal, is it making the clicking sound and work correctly but the light in the cluster doesn't work? if thats the case, that bulb could be burnt out, or it could have popped out of its place when you changed the speedo cable.
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
thanks ill try and remember that lol
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
yea it still makes the sound i guess i have to take the cluster out again
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
i knew i forgot some stuff, my lights when the doors open dont work at all, im thinking its a fuse or bulb i havent checked yet and to lock my door i have to push the lock multiple times. does any1 else have this problem?
