lexus afm
Yakuzastinger
will she ever run right?
Dec 18, 2005
60
Greensboro, NC
richen into the tens? on stock pump and injector and pressure without ANY other way to control fuel? explain to me how the ecu would know to do that?
Ill hace a dyno sheet of the difference of stock vs lex with no other changes to the vehicle posted up tomorrow nite. Its a short pull due to it leaning out more than i like.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
Jeff Lange said:
Lexus AFM + Stock Injectors + Tuning = Fine.
Lexus AFM + Stock Injectors without Tuning = Bad Idea.
Lexus AFM + 550cc Injectors without Tuning = Fine.
Thanks for clearifying that... Yes I was assuming he wasn't going to be tuning at the same time he was installing the lex.
Personally I'm going to be going with the lex+550's w/o tuning then go with maft-pro down the road
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
mkIIIman089 said:
Mine richened up right into the 10s virtually identical to the way it did with the stocker.
You either had another problem, or did something wrong.
I think it needs to be mentioned here that you reset the ECU so it could relearn with the new housing in it when you did this mod ;).
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
jetjock said:
I could answer that question but it's more fun to watch the yes no thing in action.
Jeff: edit, never mind....it's me. Eyes aren't what they used to be....
Come on JJ talk about it .....
Jet Jock ur the funniest guy on here ...... You kinda remind me of a older white Dave Chappelle. Meaning you are bluntly honest and some people find that to be offensive but you are “keeping it real” well most of the time. Even though i dont agree with you all the time.
