Lexus AFM ?????
MKIIINA
Destroyer of Turbos
Plano, TX
buy a new hose from toyota, its $32. a used one will more than likely split. and actually after 8 months or so when i went vpc i noticed small cracks starting to develop. a hardpipe replacement is the best bet.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
1. Buy new hose.
2. Dip finger in motor oil.
3. Apply motor oil to outside of AFM and inside of hose.
4. Push them together.
It's actually pretty easy if you just lube it up a bit.
shaeff
Kurt is FTMFW x2!!!!
11
Around
^ that's what i did when i was running the lex AFM. worked like a charm. :)
-shaeff
