Lexus AFM Vs. Stock Turbo AFM? Need Some Help Fellas.
Winger
29
logan
I have two AFM's here. I bought my supra from a guy that said he put in the new lexus AFM. He has RC 550's in the car already, but I wanted to make sure that it is a Lexus AFM.
Here is the part number I pulled:
On the metal case: 22250-42020
Off the electronics: 22204-42011
Here are the part numbers for my other AFM:
On metal casing: 22250-50010
off the electronics: 22204-42011
My question is whether these are both Lexus AFM's? If so what is the difference? Also which would be better for my car?
Thanks.
zman6127
ZMAN
Dec 30, 2008
91
Fort Wayne, IN
Thanks.
hey ill help ya out:biglaugh:
22250-42020-fits supra 86.5 up to prod date 05/93
22204-42011 sensor- cant get to come up...maybe a supercession? or not avail separate
22250-50010-fits 1990 lexus ls400
22204-42011 sensor-cant get to come up...maybe a supercession? or not avail separate
so ones a supra afm and the other is a lexus afm
Hope that helps you out man. let me know if you need anything else.
nsngarage
210
Pittsburgh, PA
the 42011 is lexus electronics i believe.. you'd notice a difference in the metal casing, one is WAY bigger...
The bigger would be better for your car, since you have 550's, that's a 25% fuel increase, and the lexus afm is a 25% increase in air.
89supra7mgte
797
colorado
I got two or 3 laying around none fixed my problem i was having, but the fourth which is a lex from sc400 has the same exact numbers as one off an sc300? the sc300 afm did not work but came off a running car?
Winger
29
logan
dusthead;1450540 said:
well no one knows of this problem...you asked about the AFMs being lexus or not...whats the issue?
The issue is that I have RC 550 injectors in my supra right now. The guy I bought my car from said he put on the lexus afm. I now know that he did not put that on. Everytime I hit the power band i get a ton of backfire and it won't keep accelerating. It makes sense now, being that the original afm is still on the car.
The reason I didn't notice the difference in their diameters is because I have the origianl afm on my car, I got the other one from a buddy of mine who's supra broke down.
I am installing the new lexus AFM on tomorrow, hopefully I can finally get the power out of my baby that I know it has!!
