lexus afm replica and 550 upgrade question
BOOSTEDSUPRA
THE DRIVELINE GUY
Jan 4, 2007
308
turlock, calif
:1zhelp: ok, its been a while since ive been on here, bout a year or 2, lol, my car has.....to say the least been plaged with bad luck, from blowing up, to the worst catching on fire, all in all ive kept it going, and looking pretty good i think considering, using only toyota parts to keep it running good. now that ive got new switches, emblems, bla bla replaced with new dealer ones, i want to turn my attention to the boost. i have a few mods, open air filter, ams intercooler with all hard piping, hks b.o.v., mls gasket, head rebuilt, megan 3" exhaust with hks 3" down pipe, cat delete, tru boost boost controller, eibach springs with tokiko illuminus shocks, b&m short shifter, bla bla :icon_bigg, i want to get the lipp lexas afm from jack at supra sport with the rc 550 injectors. my question is, is that a plug and play set up? or is there major tuning involved so i can stop hitting the annoying fuel cut at 13psi?! my fuel pump is stock that i know of, stock ct 26 and yes i know i need to upgrade! lol. ultimatly....can i put that set up on...and turn the boost higher?:evil2: i will get some pics on here i promise thanks for taking the time to help me out!!!
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Get a Walbro pump…. You might need to wire in the injectors but that depends on which injectors you get however the afm is plug and play. You don’t have to tune it but you will benefit by tuning the system because you are going to be pretty damn rich. You should be able to up the boost and be just fine.
Get it tuned.
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
BOOSTEDSUPRA;1146654 said:
:1zhelp: , i want to get the lipp lexas afm from jack at supra sport with the rc 550 injectors. my question is, is that a plug and play set up? or is there major tuning involved so i can stop hitting the annoying fuel cut at 13psi?!
Its kind plug and play youll need to solder/crimp your new clips for the injectors and for the afm im pretty sure youll need your stocko blackbox and honeycomb guts and refit it into the new afm.
you'll need at least a fuel computer and a dyno or a wideband to give it a tune to get it all sweet.Yeah fuel will cut will be raised.
8,898
Nick M;1018470 said:
I am impressed with Toyota engineering and the Lexus replica from Suprasport. You can't even tell it is there, except the housing is not dirty and bigger. No difference in drivability at all.
It is almost like having a Ford hot wire sensor from Hitachi.
The solder comment is spot on. What you really want to do is crimp the connection, and fill the crimp with solder.
If your car runs as designed by Toyota, it will run as designed after the Lex meter and RC injectors. If you have problems now, you will have problems after.
