Lets play "Estimate My rwhp"
empera
Authorized Vendor
Philly.
ok since i will be dynoing my car in the spring right after i get my turbo set up together which basically all i need to do is rebuild the turbo. I would like hit ~400rwhp but i would like some input. I want to get it tuned and dynoed soon so if you have any tips or comments please let me know.
Mods include:
550's, ffim w/stock tb, safc2, vpc, walbro fp, afpr, 24x12x3 ic, 2.75" ic pipes, 3" Trust Exhaust, Presicion sc61 turbo (.70 cold .68 hot), 3" dp, 2.5" test pipe, AEM WB, AEM Truboost EBC, 6 puck CN clutch, CN PP, cometic 1.31mm HG, 3angle valve job, arp studs...uhhh i think thats all thats important to mension.
Any helpful info would be greatly appreciated.
Thanks,
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
i dont know what boost you pln on running, but i'd say
1st run
379 HP 395TQ
2nd run
413 hp & 435TQ
pshh i dunno i just made up some #
shouldnt this be in General discussion...
I don't see any problem hitting 400. I made 406 @13lbs. of boost on a Garrett to4e and the same mods as you basically. I think your turbo is bigger and you have bigger piping with the ffim. I'm guessing 420rwhp @ 14lbs, and 415rwtq.
What did I win?........................:biglaugh:
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
empera said:
why would it be gen. disc. if i have a 7mgte?
well i dont see any technical Q and your title sounds like it should be, but w/e i could care less really...
so if u give out a prize...
if u go over over your out??
dbsupra90
toonar
indiucky
with same turbo, stupid rich, and auto w/ hi stall converter i hit 360/370rw at 10.5psi
other comparisons-
ken has very similar turbo and 22psi he put down ~500rw.
chris had a very similar turbo (60-1 t'netics) and put down 406rw on a mustang dyno at 17psi.
LilRedSupra
Soupy
May 8, 2006
198
Louisville, Ky
other comparisons-
Now it's all mine (60-1) :naughty:
Supracentral
10
And by the way:
3" Trust Exhaust
3" dp
2.5" test pipe
Is the definition of a bottle neck.
Get a 3" test pipe made. :)
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
LOL, Jay.....:rolleyes:
Well I'll make the assumption that you're running some C16 Happy fuel and 20+psi. :naughty:
In this case, You would be WAY in the upwards of 4xx^rwhp, if not over 500rwhp.
But even with some low boost pulls, you should still have NO problem hitting 400rwhp.
OMGWTFBBQBHG? :love:
