LED tail light conversion, clearcorners.com style. Ideas on how to?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
annoyingrob said:
The easiest way to do it is get a prototyping board, and cut it to fit the housing, then solder the LEDs onto it.
That's cool. Where's a good place to get prototyping board? I wonder how one might go about wiring a circuit to have the same led's get half voltage for dirving lights, and full voltage for braking?
HIDPLANET
89 1JZGTE
Thats what a PWM Circuit is used for. It allows you to control the amount of voltage going to the LEDs depending on what triggers the circuit.
Turbo. Targa. Life.
SupraMania Shirt Slinger!
Apr 16, 2005
1,709
O'Fallon, MO
www.geocities.com
Wow JJ, I didn't know anyone else was into LED's here :)
My dad and I just built a flashlight with a Cree in it and WOW. Even though they were $7 a pop, the first light we did was AMAZING, and the second was still about 3x brigther than the original LED.
EDIT: forgot to ask the question I was gonna ask--how the hell do you replace the third brake light? Mine's out and I can't figure out how the get the housing out of the spoiler!
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
johnathan1 said:
I can't see the video? :(
It says I need a codec to view it.
Shit, now I can't remember what codec I used to encode it. I thought it was a standard intel codec. Anyone else having problems with the video?
Easy, it's all about the resistance. Let's take a small example:
1 LED, it has a 3V operating voltage, draws 20mA of current. Let's assume a 12V source (full brightness of the brakes with the engine off, and a slightly discharged battery)
(12V-3V)/20mA = 450ohm current limiting resistor. This will operate the LED at normal brightness. If you wanted to cut that down, you could use a larger resistor. Something closer to 1Kohm would probably dim the light enough. After that, it's just simple wiring. power the lights through both electrical sources, with appropriate resistances.
As for prototyping boards, I get mine off of Ebay. I also get most of my LEDs off of Ebay, but there's a good site for them too. ledshoppe.com IIRC.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
on the bottom of the spoiler as in the wing there is cliped in panle/cover there should be some screws under it if remmber right
born2drv
1,199
Burbank, CA
I wanted to do this eventually. I just bought the reconditioned housings from wolfie with the clear corners. I just need to find time (or find someone) to get me the circuit boards and LEDs to put in them.
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
So I've basically just finished my design on this (puttin that degree to some use!!...and I'm bored as hell) and I think I'm going to try and go ahead and actually make a set. But I want to see what it looks like ON a Supra first. Does anyone happen to have any pics?
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
MidShipCivic said:
www.Hidplanet.com/forums learn all you want there.
Thanks for the link! All the info I need is there. I'm now considering using the popular new Superflux LED's spaced further apart. I'm beginning to think it looks a bit more modern, what do you guys think? (Example pics below)
I've got a spare cracked tail that I will try to separate using the oven method (250 degrees for 5 minutes) Anyone else done this successfully? I might even investigate putting the LED's into the center lens for an NSX-style full width tail light bar!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Why bother with tearing them apart? I'd build the PCB in segments (4) drop them in and solder in jumpers linking them together.
