LED Climate Control Conversion Question
87MK111Supra
San Diego
Alright, I'm in the middle of doing this conversion and I have 2 questions.
How do I get that Green tinted screen in front of the analog screen out?
And where can I get an analog that isn't green?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,269
64
Atlanta
You know- you could have just bought one of mine like a month ago. But I digress...
The green screen requires that you remove the front black 'panel' that says TEMP on it. Look through the back of the faceplate, and you'll
see a small round hole next to the green plastic. use a pencil's eraser to press slowly through that, to start pushing up the 'TEMP' plate,
that is held down by a rubbery cement. Once you get the edge up(and be careful- don't scratch or kink this panel), you can work your way around it with a battur knife, or whatever you like.
The backing of this is easily scratched, and if you do scratch it, you'll end up having whitish gouges visible on the front face of it. Any way- Once you have it completely off, you'll see that
the green panel is just held in place by a couple of tabs. you can either push the tabs out of the way(carefully) and lift the green panel out, or you can just go prison-rules on it, and break it out.
As for a replacement plastic, I suggest a similar gauge, and get it tinted- that's what I do. Where do i get this magical, unobtainable sheet plastic and tint, you ask?
SEND- $1.99 TO SUPRAGUY@AOL.COM via PAYPAL,
FOR ALL THESE AND MANY MORE ANSWERS!!!!
OPERATORS ARE STANDING BY!!!!!
just pm me if you need to know.
