OK i have been searching for the past 3 hrs with no luck so i hoping i can get an answer or linked somewhere. I installed the lexus Maf, and 550 injectors, walbro fuel pump with 12v mod, and aeromotive afpr bypassing the j tube. I have the stock idle screw set all the way in that i can get it witch looks to leave about half of the unmetered air chamber open. I have the fuel pressure set at 40 with no vacuum. I still seem to idle at 18:1. I know this is way lean. I cant seem to fix it. If i add fuel pressure im afraid when driving it will be too rich. when it was set between 45 and 50 it idles at around 17:1 but at WOT it was pig rich at 10:1 but cruising was the same at around 15. I havent tried wot throttle sense i turned the pressure down to 40. I have a way of tuning fuel but i have not yet installed but I dont see any means of tuning the idle with it and want to figure this oput first.. Any help would be great. I Have seen many post with ppl having the same issue but no one has said weather they ever fixed it or not. Could it be my ecu being bad?
Mods are 3 inch turbo back, boost at around 12 psi, and K&N Filter.
