-On a cold start it will hit 13-14afr for a second then .01 by .01 work its way to 18 and off the scale. idles high at first like normal but will NOT richen up. and of course it starts to miss fire at idle after this. If i turn it off and restart warm it will start to lean out as well.
-boost gauge (mechanical) is very slow to respond now. it will stay on 20hg of vac with heavy blips of the throttle and respond VERY slowly to boost or letting off the gas. I removed the small line to my boost gauge, and idle didnt change a bit, Clogged?
-Once warmed it will idle and drive in closped loop at a perfect 14.8-15.2, however if left to idle long enough it will climb to 16.2 and stay there if not higher.
-Unplugged o2 sensor on startup, NO change, just pegged lean.
-Leak test didnt show anything leaking.
-o2 checks out per tsrm except the heater reads 4.6 ohms (high), worth the $40 to replace? (only a few thousand miles on it as well.)
-ISC cheks out on the ohm meter as well,
-Temp/time switch for csi is BRAND new.
-IC connectors are tight and all vac lines are connected, going to ziptie all of them in a minute, but im stumped on this.
-what am i overlooking?
