leaky ps canister
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
What are you trying to say? If it's leaking, get some new hoses and clamps and tighten them down and you should be good to go. Good luck.
Tim
regular member
Oct 16, 2006
272
CA
yah man, just put some new heavy duty clamps on the hoses and you will be fine.
Mk3runner
2,033
Nor Cal
I had the same problem... cept mine had leaked dry during its down time while getting the engine together. how about filling it up then bleeding it. that solved my problem. not saying its the same case, but an easy fix if it is.
OneJoeZee
Retired Post Whore
aboard the Argama
yep. Add a PS cooler. See if it helps. With no cooler, your PS ATF can get pretty hot... Same with your fan ATF. Good to have a cooler for the fan fluid as well.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ya, im using the stock fan cooler so i have no prob with the fan. ill might as well add an oil cooler too, wow thats a lot of coolers :aigo:
OneJoeZee
Retired Post Whore
aboard the Argama
It may stop your leak because you were just boiling the ATF a bit because of no cooler or it might be something else.
Even if it's not the source of your problem, it's a good idea to use a cooler for the PS anyway. I'm using an automatic transmission cooler from autozone and mounted it behind the left foglight area.
Good luck tracking down your cap leak.
