Leaking fuel pressure regulator?
johnathan1
Supra =
Aug 19, 2005
5,056
The other day, I noticed that the vac line going to my stock FPR was looking a bit dry, so I pulled it off of the FPR, and the hose is super hard, and not soft like it should be, and I replaced it not long ago...it also smells like fuel.
So I started the car with the vac line off, and revved it a few times, and saw fuel shooting out of the vac nipple :aigo:...It wasn't an alarming amount, but still enough to cause concern...I'm guessing this means the diaphragm inside is leaking? What effect would this have on the engine? I know my 7M doesn't like to idle after a hot start lately...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Agreed...don't drive it with a leaking FPR. Not only could you go lean, but if it leaks into the bay you can have a fire on your hands. I have a stock FPR...if you need it, PM me.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,776
Long Island, Ny
Wouldn't it be running rich because its pouring fuel into the vac line? and also because its most likely not lowering the pressure from base at idle and sub boost conditions?
on boost i guess would be a guessing game but just driving around town i would think it would be rich.
