Leaking from tranny...?
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
Does the front 2 tranny plates need silicon sealed on it? its been leaking at the lower front tranny plate. i know i can just put it silicon on and see, but would like to know if trans fluid leaks from there. lmk, thanks.
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
to tell the truth, i cannot tell at the momment. All fluids are fresh fluids under 200miles. It feels like engine oil, but it has the black sluggy look which i may believe is gear oil. ?
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
thats what i was trying to say in the 1st post, does it need silicon?
here's some pics of the leak:::
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
That plate is called an 'inspection cover'. Oil that leaks from the tranny, or rear engine seal is supposed to drip out of the tiny hole there.
Imagine if you sealed that plate up. Oil would build up in there, and start soaking your clutch. Imagine that !:aigo:
89turbotoy
2 89 supras 2jzgte/single
Jul 30, 2006
309
cincinnati
smell the leaking oil. if it smells like a fat mans ass it's gear lube from the trans and if not it's oil. if it's oil bad rear main seal if it's gear lube bad front trans seal.
