Leaking EGR cause abnormal accel? if so how bad?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
Well i was just reading a post by another member who described similar problems as me, jerky acceleration seemingly like a misfire of sorts. I just changed all my sparks and no difference...my other thought was IGN coils until someone in the other thread mentioned boost leak. I have a boost leak tester and found all leaks but i cant seal my EGR. It leaks pretty steadily and its rather loud at 10PSI, would this cause jerky acceleration like i mentioned? or just a pure loss of power (which i know it will anyway but the powerband would remain smooth). If it can cause that jerky acceleration would it be safe to pull the EGR and epoxy around the seals to solve the problem?? From what i can tell the EGR leaks around teh screws in the bottom of it but you all know its in a tough location and its hard to tell for sure.
If the leak doesnt cuase this poor acceleration problem, should i look into the coils next?
BTW i have great overall acceleration, just like i said, jerky and misfire like. Also i have a low Hz knock sensor reading
