Leaking coolant from under CPS and above manifold
Is this common to leak coolant from under the CPS and above the exhaust manifold?
I can't see exactly where it is coming from without starting to remove lots of things, so I was hoping someone could help pinpoint where to look?
I'm hoping it is impossible for the headgasket to blow that badly, right?
In that case, next would be the 90 deg hose that connects the hardline around the block to the water neck.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Sik89supra;1387596 said:
Check thermostat housing where it goes onto the head, they like to leak from there too.
Mine started leaking at the water outlet as well. pretty easy to fix. I would recommend replacing the other cooling lines in the area when fixing this as well since they are easier to get to.
I've decided that now is a good time to replace the water pump, themostat, all hoses, radiator, all gaskets, and anything else that decides to break while i'm doing my replacing
I also understand that toyota red is the best coolant, Is it the best idea to go to the dealer and have them fully flush my system with their stuff? and how much might I be looking at?
