Leak behind compressor plate
zurud
351
Evansville, IN
I have boss 550 turbo. When I check for boost leak I found leak behnd compressor plate. Is this normal? I can't tighen it anymore.
zurud
351
Evansville, IN
I am using the home depot pvc pipe with air chuck. The pressure is 25 psi. The design is like your picture. Maybe I need to take it apart and look at the seal again. Thanks Dave. Yes I will be going to Indy meet.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Many turbos don't have a seal there, it's just metal on metal. My new HTA GT turbo doesn't, and neither did my upgraded CT26. The CT leaked a lot of air so I put a thin bead of silicone on it.
It seems stupid that there is no seal there, it makes it much harder to test for boost leaks when the compressor is hissing at you.
