Koyo radiator coolant capacity - please help!
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
Does anybody know the approximate coolant capacity for this radiator.
If not, is there any good rule of thumb I can use to avoid overfilling? I did a search here and on google and came up empty.
Any tips are much appreciated.
bowsercake
828
Irvine, Ca
Overfilling? Is that even possible? Just fill it up, turn on the car and let it idle until the thermostat opens and coolant goes into the engine. When the level drops fill the radiator some more. Make sure the reservoir is full also.
can't overfill, only underfill...
the only part that can be overfilled is the overflow bottle, and it will just push it out if it's overfilled...
