Knock Sensor Question
supraguy@aol
Well-Known Member
Dec 30, 2005
4,278
69
Atlanta
Hmm. I've been running knock sensors out of a '95 4-runner (square plug) on my '88 now for 4+ years, no problems.
maitai69691
280
hilo hawaii
thats good to hear...was woundering where i could get a new plug end for the knock sensor not the sensor it self got one i need to replace
shaeff
Kurt is FTMFW x2!!!!
11
Around
Assuming you've got the 86.5-91? round style plugs, get them at any Toyota dealer. PN: 82219-89103
ashiharausa
suprazone
hi i have a 87 supra manual would like to know where is the knock sensor exact location at or pix will help? also giving me check injin code 14 ....44 ...52....gelbertc@yahoo thanks...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,278
69
Atlanta
If you have a 7mgte, you have two knock sensors; one directly behind the alternator, halfway down the block, and one at the same height farther back, nearly behind the starter.
If you have a 7mge, then you have one, and it's between the two aforementioned locations.
Chrisco
Build in Progress
Jan 4, 2009
62
Downers Grove, IL
Rollus;1725857 said:
I'm sure squared and round aren't compatible.
In Epc, there are 2 reference : 1 Toyota and 1 Denso. We cannot exhange.
I've just had the same issue 10 days ago.
Voltage checking is a good way to check wiring.
Can anyone confirm whether or not the square and round plug knock sensors are compatible and can be used together? I am swapping a '91 GTE engine into my '92 (originally N/A) chassis and the '91 engine had a broken round plug knock sensor. I have the square plug sensor and harness connector from the '92 GE engine and would rather use those than spending ~$100 on another sensor if I don't need to.
Thanks,
Chris
supraguy@aol
Well-Known Member
Dec 30, 2005
4,278
69
Atlanta
Maybe someone else can chime in, but how often do these things actually go bad?
I imagine it's the wiring that ends up being the culprit 99 times out of 100.
