key cylinder lock
torontosupra89
10
toronto
here is the problem...my key is very old and worn out and now i cant turn it out of the lock position to take the key cylinder out...does anyone kno anyother way of taking that stupid thing out cuz it is frustrating me :S lol...
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I meant lock picks... ;)
I don't think there's another way to remove the cylinder... but I've never had to. Are you trying to remove the internal barrel or the whole lock? Which lock is this anyway, the ignition?
EDIT: If you're trying to remove the barrel it doesn't look like there are any access panels in the door lock housing (woot for Toyota, bad for your situation). The only two options to remove the barrel is either picking or a jeweler's screwdriver and a couple shims. http://www.supramania.com/forums/showthread.php?t=39358&highlight=rebuild+lock
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
you can always drill out the center of the lock and allow it to fall in on it's self. When I get to work tomorrow I will see what the process is for removing the cylinder.
casgallo
Not a lurker :)
Apr 3, 2005
68
New York
you need to have all the plastic trim around the lock cylinder off. then turn the key to the lock position, then right above the lock cylinder there will be a hole and you need to shove/apply pressure in that hole and then pull the lock cylinder out.
as for the key get a another key? use a spare/ get one cut/ go to toyota.
or just keep wiggling till she turns!
torontosupra89
10
toronto
billspreston01 said:
the key code is stamped on the passenger side door lock housing. 6 digits. Get that number and have toyota cut you a new key.
damit i should have asked you guys earlier i ordered a new steering colunm which is on its way so i cant even stop it well i guess now i kno....you wat i went to the dealer ship and told them that i needed a new key cuz my old one is all worn out there like oh if you dont have the code we cant make it they never said that its on the passenger side :S
