jza80 radiator into a70
disturbed1
372
perth
anyone know if u could easily mount a jza80 radiator into an a70?
dont expect one to bolt straight in - but do the bottom locating pins line up to the factory chassis mounts? or does the core even fit between the chassis legs?
the top mounting brackets isnt an issue since i no longer run the factory radiator support bar.
cheers
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
The real question is why would you want to use a MKIV radiator in a MKIII? I've used a Koyo race radiator in the past with no problems with my 1J and have never heard any bad things other than a radiator that had shitty looking welds (not the typical Koyo quality).
