Jza70 oil cooler
mattsplat72
is sofa king
Jan 17, 2006
1,738
I am not sure if this is the right place for this. I am stripping a Jza clip of useable parts. I found what I think is an oil cooler It is about two feet long has a single pipe that loops with heat sink fins was attatched to bumper support by three ten mm bolts along with this is the outside temp sensor so I believe that when the bumper support is on the car the "cooler" is on the underside. if this is what I assume it is can I get a detailed description or pics of the routing to and from so I can use this on my ma70. I totally lucked out with this. I get all the usuable parts just for scraping it when I am done. The guy just wanted the 1j for his cressy I get every thing else woo hooo
A pic would help, but it sounds like the power steering cooler found on later model cars.
soapra
860
VVTi'n, CA
www.kaizenmotorsport.com
That is your hydro fan cooler.
mattsplat72
is sofa king
Jan 17, 2006
1,738
I dont see why it wouldn't work. Might be a cool thing to show off. Meh! I might just strip the clip down and bin it up. I want to do a swap in the future so I might as well try to save myself some money. Is there a tsrm in english for the Jza70 say maybe Australian?
^^^ A very good candidate for conversion to a full flow, thermostat controlled oil-to-air cooler circuit ;)
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Supra&
