just runs like poop
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
so ya after i get my tts and tps this wk. i will adjust the timing. and hopefully shell be fine after that. i know both these sensors are makin her run like doo doo.
jetjock
creepy-ass cracka
9,439
CTS is Coolant Temperature Sensor. TTS is Thermo Time Switch. And yes, if either are busted it could cause hard starting because the ecu also has control over the cold start injector. Who is in control depends on the temperature. Between 20 and 40C the ecu will run the CSI for a max of 3 seconds. It uses the CTS to decide. Below 20C the TTS comes into play. It also uses the coolant temp but does so in a different way. It has a max on time of about 8 seconds but it'd have to be mighty cold for that to happen.
Btw, a bad TTS will not cause a code 22 so you still must have a problem in the CTS. And send your old TPS to me...it may not be bad and I could use a spare ;)
jetjock
creepy-ass cracka
9,439
TTS won't set any code. Not monitored. You say the sensor on top of the housing is broken and that should be the TTS. But you also say you had a code 22. That would be the CTS (which is monitored) so something is goofy
Understand, there may be differences in T stat housings between model years I'm not aware of but the CTS should have a green connector. Bottom switch? Usually for the AC fans or for AC cutout on high temp.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
supramike7m said:
what code would a tts throw? also what is the switch on the bottom of the housing?
i was lookin and code 51 is also for a/c, i dont have any a/c components, connectors hooked up. this could be the reason for code 51? if so maybe my tps is fine. what do ya think?
jetjock
creepy-ass cracka
9,439
Mike, there are lots of posts that cover this (one of which I just posted today) but no, if you don't have AC it won't be the cause of code 51.
It's easy to check your TPS and CTS, either on the car or off. Search todays posts for advice or read the manual. No manual? For shame. Look at the one online and after go buy one. It'll answer everything you asked and more.
Prescott: great place btw....
87trbo
houston,texas
i have a repair manual for '72 through '92 supra and the book tells me that code 22 is coolant temp. sensor signal, 51 is air conditioner switch or neutral start switch signal and 52 is a knock sensor signal (1985 and later models only)
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
ok so i fixed the code 22 with a new coolant temp sensor. jet jock what do you think could be the problem with the tps? since you think its probably fine. what should i do? thanks
Mike
jetjock
creepy-ass cracka
9,439
Since I think it's fine you should do as I asked and send it to me ;).
I've already told you what to do. Several times. Test the TPS using either a your own manual or the online one. It's not difficult to do. Or search the forum for other TPS posts. If you don't own a manual and intend to keep the car go out and buy one, a real Toyota one. I can't help you if you won't help yourself.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
where can i get the manaul, any parts store?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I think he means it is available at the Toyota dealer, not a haynes book.
