Well I just installed a set of JDM 440cc injectors and everything went good. The only weird thing is that on my low throttle and idle settings on my AFC, I started out with a -15% the car was running lean and crappy, so I zeroed out the afc and now it runs great (14.7). I am running a 10.1 AFR at WOT, which is what was expected so I definitely can take some fuel out in the top end. But my idle and low throttle like it zeroed out. Do you think that this is because the car is in closed loop and the computer is adjusting it to stoich by itself? I checked and their are no vacuum leaks.
