Just bought a Supra, Needs a mad tune-up. Help
Supra-K
233
Victorville CA
Hey, I just bought this supra and its in need of a tune up, well since I dont have much history on this car Im just going to do the most complete tune up I can, heres what I got planned:
1. Oil change/filter
2. All fluids in tranny, diffs, radi., etc, changed
3. any leaky house fixed including gaskets
4. plugs, wires, ingnition coil(would I need coils?) or wait I think its a module let me know on that
5. fuel filter, with a cleaner added to fuel
6. Timing
7. valve Clearance adjustment(anyone know how to do that, guessing haynes repair books knows best)
O on the valves its a 7m-gte with the NA cam shafts so i wouldnt know if that would have any affect on clearance.
uhh...thats all I got so far any questions I asked in there could you help me with and anythiong youd like to add please feel free cause this car needs it.
pogoism9
1UZ for me!
May 18, 2007
367
fredericksburg, va
Good idea
Also, not a bad idea
In theory, its a good idea, especially on a turbo. The reality of it is, unless you can do it all yourself, its not very cost effective. Especially if the oil pan gasket is leaking.
Plugs and wires should be sufficient. The coil packs are tough, and so is the ignitor.
The fuel filter is a bastard to get to. You have been warned. its above the rear end on the underbody. Fuel additive is personal preference.
6. Timing
Are you talking about the belt? or just the ignition timing?
This may be a bit of overkill. Of the 4 Supra's that i owned (as well as a Celica, and 2 MR2's that had identical style of valvetrain), I never really needed to set clearances and all was fine. Your mileage may vary.
Supra-K
233
Victorville CA
o forgot to add, has comsmetic mhg, and ARP head studs so I might be good there, O i ahd a question too, the valves are pretty chattery or loud, it has NA camshafts so could that be causeing the problem or do they just need an adjustment, thanks for the replies.
Supra-K
233
Victorville CA
O btw Im wanting the most major tune-up you can get, I want to start fresh and the timing Id like both belt and ignition, feel free to add anything else in the tune-up. O sorry another question, should there be a tad bit of oil in the intake, I think it might be from overfilling the block with oil but what else could it be, or is it even bad? thanks
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
You see guys, THIS is the kind of person I want on this forum. Asks a good question, with detail, and bookmarks the tsrm after just seeing it!
I hope you stay in this forum for the long run.
Anyway, pogoism9 made it clear as water on what to do.
-Thomas
Supra-K
233
Victorville CA
hey anyone know where I can go to get check engine light code read? I know its a OBD I but I went to autozone and all they had was a OBD II, just want to see what code pops up casue I have no clue what it could be.
Supra-K
233
Victorville CA
-Thomas
Thanks man, and I do plan to stay, see ive been on many forums before and basically all you have to do is search and if you dont find youre answer there then post a topic, easy 1-2 steps dont know why people cant get that:3d_frown:
Supra-K said:
aight cool, know of any place that actually has the code reader?
You'll have to read your own codes. Your car is too old for somewhere like autozone or Advance to do it. It's pretty self explanatory in the thread I posted. If you can't figure it out, send me a pm.
