I've Tried It 365: My Full-Year Experience with Quick Extender Pro
Hey everyone
After a full 12 months of using the Quick Extender Pro daily, I wanted to write an updated and honest review of my experience. If you're wondering whether this device actually works — this is a no-fluff breakdown of my yearlong journey, how I used it, the routine I built, the gains I achieved, and the lessons I learned along the way.
First impressions:
You don’t need to use all 4000g tension out of the box. Just be consistent, patient, and smart with your progress.
If you’re ready to try it for yourself, here’s the official discount link I used: https://geni.us/qep20
Let me know if you have questions. I’ve been through it all and I’m happy to help.
Hey everyone
Why I Picked Quick Extender Pro
Before purchasing, I spent weeks comparing devices. I looked at Penimaster PRO, Phallosan Forte, and Quick Extender Pro. What stood out to me about QEP was:- Higher tension capability (up to 4000g)
- Simplicity and durability of rod-based systems
- DSS (Double Strap Support) system for security
- Affordable packages for long-term use
- Clear instruction manual and support
What Came in the Box
The Deluxe Limited Edition package included:- Quick Extender Pro base device
- DSS double-strap system
- 4000g tension springs
- Multiple elongation rods
- Extra silicone tubes and comfort pads
- Memory foam base pad
- Travel/storage case
- Measuring ruler
- Gauze, alcohol wipes, instructional DVD/manual
Assembly & First Use
It took me about 15–20 minutes to get the device assembled and properly fitted the first time. The instructional guide helped a lot.First impressions:
- Comfortable enough once you get the straps right
- Secure and didn’t feel like it would slip
- Definitely noticeable when worn, but not painful
Month-by-Month Progress & Routine Summary
Month | Daily Wear Time | Bar Length Progress | Routine Notes |
Month 1 | 1.5–3 hours | Base length only | Focused on comfort, wrapping gauze under straps, short sessions |
Month 2 | 3–4.5 hours | +1st rod pair | Split into 2 sessions, tracked use in Google Sheets |
Month 3 | 4–6 hours | +2nd rod pair | Warm cloth post-session, improved tension control |
Month 4 | 5–6 hours | +3rd rod pair | No strap slips, DSS felt very stable |
Month 5 | 5–6 hours | Same as month 4 | Focused on maintaining tension, no rapid lengthening |
Month 6 | 6 hours | +4th rod pair | Warm-ups before sessions, tracked comfort points |
Month 7 | 6–6.5 hours | +5th rod pair | No irritation, solid daily routine built |
Month 8 | 6–7 hours | Same as month 7 | Introduced occasional 1-day breaks |
Month 9 | 6–7 hours | +6th rod pair | Longest daily averages so far |
Month 10 | 6–8 hours | Max rod length for me | Maxed out safe tension I could handle |
Month 11 | 6–8 hours | Maintained | Recovery days added as needed |
Month 12 | 6–8 hours | Same | Final measurements and wrap-up phase |
The 12-Month Program
Month 1–2: Adaptation Phase
- Wore it for 1.5 to 3 hours daily
- Focused on correct strap tension and avoiding pressure points
- Used gauze underneath the straps for added comfort
- Slowly extended bars every 1–2 weeks
Month 3–6: Growth Phase
- Averaged 4 to 6 hours per day
- Divided into 2–3 sessions
- Started seeing measurable progress in stretched length
- Introduced warm compress pre- and post-session for better blood flow
Month 7–9: Consistency Phase
- Maintained 6 hours/day regularly
- Tracked every session in a spreadsheet (hours, bar length, comfort)
- Noticed improvements in flaccid length and straightness
- Zero issues with strap slipping or fatigue thanks to DSS system
Month 10–12: Final Push
- Pushed up to 7–8 hours daily on weekends
- Focused on maintaining tension and endurance
- Results were very visible and measurable
- No longer experienced soreness or irritation
My Routine
I kept it simple and structured:- Morning: 2 hours
- Afternoon: 2 hours
- Evening: 2–3 hours (while watching TV or working at the desk)
- Always wrap gauze under the straps
- Don’t overtighten
- Take 5-min breaks every 90 mins
- Use a warm cloth post-session to reduce skin redness
Final Results After 12 Months
Measurements:- Baseline BPEL (Stretched Length): 5.8 inches
- Flaccid Length: 4.1 inches
- After 12 Months:
- BPEL: 7.1 inches
- Flaccid Length: 5.1 inches
- +1.3 inches stretched
- +1 inch flaccid
What I Tracked
I used Google Sheets to track daily use:- Date
- Hours worn
- Weekly total
- Bar length used
- Comfort notes
Pros and Cons After 365 Days
Pros:- Real, visible, measurable results
- No surgery or pills required
- Strong and reliable construction
- DSS system is super stable
- Excellent support and documentation
- Needs real commitment (6 hours/day minimum)
- Not stealthy for outside use
- Some soreness early on if you overdo it
- Not cheap, but totally worth it for the long haul
Would I Recommend It?
Absolutely. If you're serious about making a change and willing to commit to a program, Quick Extender Pro delivers.- The Deluxe Limited Edition was the perfect middle ground for me — not the cheapest, but gave me everything I needed.
- For anyone dealing with curvature or Peyronie’s, they have a dedicated edition with the same technology: https://geni.us/qep-peyronies
Final Thoughts
Quick Extender Pro isn’t a gimmick. It’s not a magic pill. But it is a tool that works if you do. My body changed, my confidence improved, and I built a routine I was proud of.You don’t need to use all 4000g tension out of the box. Just be consistent, patient, and smart with your progress.
