i have been thinking about it more and more... i put my r154 on my 2jz but i did not torque it like the tsrm said to torque a flywheel to the 2jz... it said to do 43 ft/lbs and then turn an extra 90 degrees. i think i might've skipped the 90 deg part... used loctite and ARP bolts. will this be a problem? should i fix it while the engine is still out of the car?
i planned on throwing in a new clutch in right after i break this one in
but if i take this one off again i might as well get the new clutch now redo the flywheel install.... anyone have thoughts or input?
think my problem was looking at the 7mgte tsrm and the 2jzgte tsrm at the same time =( i greased up according to the v160 method as well.
