It started!!!! TIMING IS WAY OFFFFFF
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
johnathan1 said:
That would definitely cause problems...you could use some FIPG or silicone temporarily. Is it making any squealing noises?
I actually heard some kinda popping noise now and then that sounded like air escaping, kinda like a compression leak from that area, my friend keyed into that area quick but it didnt click, so you think this is it?
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
johnathan1 said:
If there is a vacuum leak in that area, the carb cleaner will get sucked into it, and burned in the engine, raising the idle... If there is no leak, the idle will not change.
OH THAT AREA, Im sorry I misread and saw into the TB for some reason, sorry was talking to a mechanic today earlier. Alright, Ill try that, the idle isnt stable as it is, the car dies LOL, Ill try this though.
T
The Weather Man
Guest
Ive got that gasket new if you need it. PM me if so! I can easily over night it for ya!
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
FOUND THE PROBLEM!!! At least I think I did, anyways, my battery is charging, it was dead, I wasnt using it last night to start it in case u ask. Anyways
The vac line that runs from pass side firewall, to side of intake plenum and behind cruise control thingy, WASNT CONNECTED AT ALL... think that was it?
NgoFcukinWay
Formerly Got Boost?
Apr 3, 2005
493
Houston, Tx
think we ran outta that too. btw, anyone have pics of how the ECU originally was mounted under the glove box? I don't remember how it was mounted when I took it outta his glove box....-_-;;
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
its seasy, there just two screws holding it in place, there is a little hole in the bracket thing on the ecu, and two holes on the dash, they can only go in one way.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Yeah and you WILL be fixing this, not me hahah.
