ISCV air filter? (stock manifold)
scotty
476
Norway
scottnicholas.net
Hey. So I've come to a point where I've only got one thing running to the accordion hose; the ISCV. Is it possible to run a very short hose and then a air filter on it? Or does it need to be vacuum from turbo inlet?
If you're still running an AFM, then the air going to the ISCV has to be metered.
You should also have a PCV line running to the accordian...
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
Is the PCV 100% required? I modified my stock intake manifold to be an FFIM and the throttle is a bit too forward to complete the circuit with it.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
Poodles;1629044 said:
Unless you don't like your rings, yes.
All right. So, any possible way to make an alternate routing then? I was planning on making a catch can but need to know how to finish the circuit with something other than the TB.
