ISC questions, ECU questions re: auto to 5-spd
born2drv
1,199
Burbank, CA
I'm having an idling issue as some of you know. (my idle is anywhere from 1500 cold to 1200 warm). So I've been doing up some reading up and I started looking into the ISC.
Turns out that the ISC gets a variety of inputs including from the auto tranny to set the correct idle speed. Now if I did the 5-spd swap, will it have issues if these sensors or inputs are not giving any feedback? Should I look into getting an ECU from a 5-spd?
You'll need a 5 speed ECU...you are correct about the inputs. You can use a auto harness (same year) with a 5 speed ECU, but you can't use a 5 speed harness with an auto ECU.
There are some other differences in the sensors (neutral start switch comes to mind).
born2drv
1,199
Burbank, CA
Cool thanks a lot.... let me ask you one more thing if you don't mind :)
My car is an 88, Turbo, TEMS, ABS
Do I have to get an ECU from a car with all those options? Will 86.5-88 work, or does it have to be 88?
Thanks again!
You need a Turbo ECU from an '88...yellow plugs. TEMS should not matter...ABS, that I'm not sure of.
