I'm having a problem with what I think is fuel cut. I'm running about 8-9lbs of boost and it seems like it's hitting fuel cut. I have a K&N intake, hardpipe w/ bov instead of accordian pipe, with the stock turbo elbow & dp to a 3" exhaust (no cats or resonators). I've checked the ic piping for leaks and even removed the intercooler (wich has been patched up, so I thought an air leak will cause the turbo to have to pull more air in than needed causing me to hit fuel cut).. even with my patchy intercooler removed I'm stilling having the same issue.
at full boost (most commonly in 3rd and 4th gear) the ecu seems to stop the fuel cause the car to stop a bit, then the check engine light comes on for a few seconds then goes away. Is this fuel cut or is it the ecu detecting knock and pulling the timing on me for a second?
Could it be that my intake and exhaust are flowing so well that I'm just hitting fuel cut (wich is supposedly around 11-14psi)? Any help would be great here!
