Is fuel cut dangerous?
IndigoMKII
2,181
Madison, Virginia
jake8790;1909798 said:
I've been hitting fuel cut when its cold outside. Is it harmful to the car?
Seems you're running a 57 trim turbo with no lex afm. I did the same thing and when I opened up the turbo elbow, it did 11 psi without a boost controller which was hitting fuel cut.
Fuel cut isn't harmful persay, it's a built in safety measure. Fuel cut is keeping you from harming your car. Easiest way around it is 550cc injectors and the lex afm.
jake8790
Life's too short for N/A
Dec 18, 2011
395
Oregon
I can't turn down the boost. I know its not good for the car, I'm just wondering if there is any danger of cracked ringlands, BHG, etc. because of fuel getting cut off. A/F stays at 11.0 or so until fuel cut.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
If you are worried about the engine running lean because the fuel is being cut off... It won't happen.
FCO is a built in safety, and Toyota wouldn't design it to cause bigger problems.
jake8790
Dec 18, 2011
395
Oregon
This is what I needed to know. Thanks.
DeMoN2318
572
Arizona
jetjock;1909955 said:
Why did you think it would be harmful? Doesn't make sense.
Probabaly just because it is pretty violent when it happens. I know when I first hit fuel cut when I bought my first turbo I was like WTF!! Did I blow the motor already?
It's just a shock when you are pulling hard then lose all power and jerk forward.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I wondered at first about it "running lean" with a partial fuel delivery, but I'm satisfied that doesn't happen. FCO also happens when you let the throttle snap back to closed with engine RPM over about 2,000 RPM or so, too. That happens often enough to assure me that it's both safe from an air/fuel mix point of view as well as from a mechanical stress point of view. If anything, the stress on the motor is greater when you snap the throttle closed, since with the throttle plate closed, engine braking is greater. (Assuming that your clutch is engaged, of course.)
IndigoMKII
2,181
Madison, Virginia
What?
Especially this part "FCO also happens when you let the throttle snap back to closed with engine RPM over about 2,000 RPM or so, too."
jake8790
Dec 18, 2011
395
Oregon
IndigoMKII;1910128 said:
What?
The ECU shuts off the injectors with the throttle closed under engine braking.
Running lean right when fuel cut happened is what worried me, now I know that's not the case.
Oct 11, 2005
3,822
26
Thousand Oaks, CA
Not that it really matters, but there is a delay after the throttle closes before overrun FC is activated.
8,897
No. Running lean is harmfull. Shutting the fuel off and using the engine like a compression brake does not hurt it. Partially fueling at that point is harmfull.
DeMoN2318
572
Arizona
Is there anyway to adjust the boost without having a tuneable ECU? Is there a boost controler that can be used with the stock ct26?
I can't get through third without hitting fuel cut...
