Intercoolers + piping?
bobpogoman
213
Quebec, Canada
i thought about these
http://www.suprasport.com/Spearco-R...ooler-Kit-for-Toyota-Supra-MK3_p_48-1586.html
http://www.suprasport.com/LIPP-Aluminum-Intercooler-Piping_p_48-344.html
will it fit great?? i know spearco replica intercooler is in and out 2.5 inches, the kit that make it fit the stock ic piping is 2.5 inches too? or it do a 2.5:2.0 inches conversion?
so i need that ic kit and the lipp ic piping 2.5 inches, and for my turbo inlet im not sure, i got a ct-26 60-1 trim, what is the inlet??
Jack
358
Stillwater, MN
How about this......
I will have a mk3 in the shop next week and I will see if the X02 IC will fit the LIPP Ic kit. It will be incorporated into the LIPP kit when everything works out OK
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
The kits from the first post should work, I would install the piping first, then mount the IC up where it needs to be according to where the IC pipes are pointing.
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
IIRC the outlet of the ct-26 is about 2 1/4 inch.
