Intercoolers: internal fins or not? Which is better?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
^Yep, there's not much difference between ebay intercooler cores and name brand ones. This is one thing you can get off ebay and the item be very close to the same craftsmanship and functionality of it's name brand counterpart ;). The main difference between ebay IC and others are the endtanks.
Search for a closeup pic of a spearco IC core, they're a lot alike.
BTW: You got lofty power goals with a big ass IC like that one don't you ;). If you don't plan on going over 500 HP I would think about getting a smaller IC...
rakkasan
Currahee!!
Fort Campbell, KY
One difference that quality can make is how straight & true the fins are. If they aren't true, it'll create turbulance & reduce effiency.
About your comment about size, I choose on that one might consider too large for my application (24"x12"x4"). I'm willing to sacrific some spool in efforts to cool the chage as much as possible, I don't want any knocking/detonation. Using a larger IC means lower velocity through the IC & that will cool the charge more. My .02
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
i agree with what rakassan is saying and ill add something as well. You have to choose which IC and piping you have according to your turbo size. Too small will not flow enough for it, and too large will actually create lag. If you are using a CT26 then usually these aren't problems but i wouldn't run anything larger then a 2.5 Inch piping to go with the little bugger.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
You've got a good point there. Anything you go with over the stock IC is going to be a better option anyways, so it's really a win/win situation in your case. Plus you'll have that large IC if you ever feel the need to make even more power ;).
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I've got a spearco replica intercooler now with a 57 trim CT26, 550's, lex, 2.5" piping, etc. I'm putting on a bomex bumper that's got this huge open mouth on it and I thought I might upgrade my IC for both looks and performance. I'd probably keep the piping the same, just swap in a bigger IC. Is the big one above (32x12x4) going to cause too much lag? Will I notice a difference? Surely someone here is running one this size and can offer their feedback. Thanks
Also as a side note, how do you guys clean the bugs out of these things???
TobyCat
470
Vancouver BC
is your spearco replica and end to end IC, or is the in/out both on the same size like with the stockers? You might have to redo your IC piping...
Oh bugs. I've only dealt with trying to get them off of a radiator in the past. I dunno of any easy way except lots of spare time and being careful :(
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I'd probably redo the IC pipes. My spearco replica has really strong fins that don't really bend. I wouldn't want to be cleaning bugs out of something that the fins are gonna get bent out of shape.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Actually the fins are called turbulators and are to purposely create turbulance and there for raise effiency by slowing down the flow rate and increasing surface area.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
when i look though my core and cpmpare it to ebay there is big diff
i remmber when the frist batch of ic' off ebay they ahe liek no fin count at all
now aday there gettign more and more fins but still not as many as my graret core
supra90turbo
shaeff is FTMFW!
MA, 01440
My PTE IC doesn't have internal fins a.k.a. turbulators (thank you for using proper terminology chris :drink1:)
I've been toying with the idea of picking up one of those ebay 4" thick ones as they all seem to be of excellent quality.
Ryan, let's not get into another big intercooler "discussion".
NashMan
Aug 5, 2005
4,940
17
Victoria BC
dude what doy ou mena you pte aka percstion ic does not have fins that make's no sence pte/perstion is joind at the hip with grarret
hummmmmm?????
