intercooler
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Basically the powerband is bumped down few hundred RPM's, maybe as much as 1000? I still don't see a need for 3" IC piping though, you think if the powerband is getting moved down a lot and critical velocity is being reached earlier on with 2.5" piping, then a bump to 2.75" would be in store...
8,900
Needs and requirements of exhuast piping and intake piping are not related.
edit: they are related, but not the same. I misstated that.
8,900
When reading intercooler FAQ's, I can't find any that suggest smaller intercoolers for smaller engines or horsepower. You would have to go into the airflow, which I am not doing.
Smaller turbo yes, but the intercooler seems to not matter, to a point. It does seem like really large piping will hurt veolocity, as it does it with intake manifolds and cylinder head ports.
SS5: Just reporting my real world findings, I used to stick with the theoretical when sizing pipes and the 3540R on 2.5" pipes at 20 psi should have been no where near Critical and on 3" should be a laggy bitch but isn't even close even with a 1.06ar Hotside.
t4boost
I gotta have my boost!
Mar 23, 2007
106
Arizona
Ok 1 more question, Would you recomend useing 2.5 in IC pipe with the Q45 throttle body ( that I just bought ) which is about 3.5 inches in diameter?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That doesn't really matter, you need to match the piping to the turbo and what you goals are. The throttle body itself is so short that the size difference is negligable (sp?), just as long as you have calculated what size piping you need and it comes out to you needing 2.5", then just make sure the smallest part of you piping is indeed 2.5".
I suggest reading this to help you decide what you need ;)
http://www.supramania.com/forums/showthread.php?p=608539#post608539
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Responsive for your setup maybe. Again, tune your setup for what your goals are, other people's will be different.
Your statement is confusing. 2.5" tubed inlet of what? You just said using 3" piping....
jdub
Feb 10, 2006
10,730
Valley of the Sun
The Q45 ID is 80mm...that's 3.15". A throttle body is more restrictive compared to the same size pipe diameter due to the throttle plate. You want the TB a 1/2" or so larger in diameter than your piping.
SS5 is correct...you choose piping diameter to suit the flow of the specific turbo. The piping/IC set-up has an effect...a FFIM has much more of a direct routing (less bends/length) than the stock route. Pressure drop across the IC does too.
Like IJ said above, the new GT series turbos have better flow a lot earlier in the rpm band...you may want larger piping diameter to support it. How you run the motor, specifically where in the rpm band you spend the most time, and how you want it to perform in this regime is what drives your decision.
