interchangable wiper arms? Are they all the same?
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
I would like to upgrade to the clip on ones if possible...maybe off another toyota? Does anyone know if the all the supra wiper arms are the same screw-in type? ANY HELP IS APPRECIATED!
thanks, t3d
te72
Classifieds Moderator
6,602
WHYoming
From what I understand, the OEM blades themselves are best at wiping the curvature of our windshield... I've had alright luck with the clip on ones for the Mk3, but the ones I have on the Mk2 are horrible...
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
the wiper arm is the problem that I want to replace. The wiper arm is bent due the wiper blade construction coming apart. So if I could replace the arms from a newer vehicle and have a lot more options on blades, that would be a hell of a lot easier in the long run
te72
6,602
WHYoming
Ahh, I'm sorry, I misunderstood (or likely misread) what you were needing. Sorry about that, and good luck!
Have to get teh same arm length and then the same wiper length. Im 99% sure that toyota uses the same size for all the cars but i can be certian. Maybe if you know someone with a newer toyota swap arms real fast.
