Am in the process of doing a turbo conversion. I understand the tach electronics ar different on NA and turbo cars. I am swapping a complete cluster from a turbo into my NA chassis. Is the cluster plug and play or do I also need to swap harness? Also, can I run the NA voltmeter in place of the boost guage if harness doesnt need to be swapped? Will be using aftermarket boost gauge mounted elsewhere in car.
